That would be great if he could look at it again. Seems to be just the one error on line 755.
Replace that parseDescriptionAsMap method with this and that error should go away.
def parseDescriptionAsMap(description) {
description.split(",").inject([:]) { map, param ->
def nameAndValue = param.split(":")
if (nameAndValue.length == 2) map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
else map += [(nameAndValue[0].trim()):""]
That worked for that error but now it is giving this error:
errorjava.lang.IllegalArgumentException: Text must not be null or empty on line 264 (parse)
Here is a version that is working for me. Give it a shot
* Copyright 2016 Eric Maycock
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* SmartLife RGBW Controller
* Author: Eric Maycock (erocm123) and updated by cjcharles
* Date: 2018-05-03
import groovy.json.JsonSlurper
import groovy.util.XmlSlurper
metadata {
definition (name: "SmartLife RGBW Controller", namespace: "erocm123", author: "Eric Maycock") {
capability "Switch Level"
capability "Actuator"
capability "Color Control"
capability "Switch"
capability "Refresh"
capability "Sensor"
capability "Configuration"
capability "Health Check"
(1..6).each { n ->
attribute "switch$n", "enum", ["on", "off"]
command "on$n"
command "off$n"
command "on"
command "off"
command "reset"
command "setProgram"
command "setWhiteLevel"
command "redOn"
command "redOff"
command "greenOn"
command "greenOff"
command "blueOn"
command "blueOff"
command "white1On"
command "white1Off"
command "white2On"
command "white2Off"
command "setRedLevel"
command "setGreenLevel"
command "setBlueLevel"
command "setWhite1Level"
command "setWhite2Level"
simulator {
preferences {
input description: "Once you change values on this page, the corner of the \"configuration\" icon will change orange until all configuration parameters are updated.", title: "Settings", displayDuringSetup: false, type: "paragraph", element: "paragraph"
generate_preferences(configuration_model())
tiles (scale: 2){
multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "off", label:'${name}', action:"switch.on", icon:"st.lights.philips.hue-single", backgroundColor:"#ffffff", nextState:"turningOn"
attributeState "on", label:'${name}', action:"switch.off", icon:"st.lights.philips.hue-single", backgroundColor:"#00a0dc", nextState:"turningOff"
attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.lights.philips.hue-single", backgroundColor:"#00a0dc", nextState:"turningOff"
attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.lights.philips.hue-single", backgroundColor:"#ffffff", nextState:"turningOn"
tileAttribute ("device.level", key: "SLIDER_CONTROL") {
attributeState "level", action:"switch level.setLevel"
tileAttribute ("device.color", key: "COLOR_CONTROL") {
attributeState "color", action:"setColor"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
standardTile("configure", "device.needUpdate", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "NO" , label:'', action:"configuration.configure", icon:"http://cdn.device-icons.smartthings.com/secondary/configure@2x.png"
state "YES", label:'', action:"configuration.configure", icon:"https://github.com/erocm123/SmartThingsPublic/raw/master/devicetypes/erocm123/qubino-flush-1d-relay.src/configure@2x.png"
standardTile("red", "device.red", height: 1, width: 1, inactiveLabel: false, decoration: "flat", canChangeIcon: false) {
state "off", label:"R", action:"redOn", icon:"st.illuminance.illuminance.dark", backgroundColor:"#cccccc"
state "on", label:"R", action:"redOff", icon:"st.illuminance.illuminance.bright", backgroundColor:"#FF0000"
controlTile("redSliderControl", "device.redLevel", "slider", height: 1, width: 4, inactiveLabel: false) {
state "redLevel", action:"setRedLevel"
valueTile("redValueTile", "device.redLevel", height: 1, width: 1) {
state "redLevel", label:'${currentValue}%'
standardTile("green", "device.green", height: 1, width: 1, inactiveLabel: false, decoration: "flat", canChangeIcon: false) {
state "off", label:"G", action:"greenOn", icon:"st.illuminance.illuminance.dark", backgroundColor:"#cccccc"
state "on", label:"G", action:"greenOff", icon:"st.illuminance.illuminance.bright", backgroundColor:"#00FF00"
controlTile("greenSliderControl", "device.greenLevel", "slider", height: 1, width: 4, inactiveLabel: false) {
state "greenLevel", action:"setGreenLevel"
valueTile("greenValueTile", "device.greenLevel", height: 1, width: 1) {
state "greenLevel", label:'${currentValue}%'
standardTile("blue", "device.blue", height: 1, width:1, inactiveLabel: false, decoration: "flat", canChangeIcon: false) {
state "off", label:"B", action:"blueOn", icon:"st.illuminance.illuminance.dark", backgroundColor:"#cccccc"
state "on", label:"B", action:"blueOff", icon:"st.illuminance.illuminance.bright", backgroundColor:"#0000FF"
controlTile("blueSliderControl", "device.blueLevel", "slider", height: 1, width: 4, inactiveLabel: false) {
state "blueLevel", action:"setBlueLevel"
valueTile("blueValueTile", "device.blueLevel", height: 1, width: 1) {
state "blueLevel", label:'${currentValue}%'
standardTile("white1", "device.white1", height: 1, width: 1, inactiveLabel: false, decoration: "flat", canChangeIcon: false) {
state "off", label:"W1", action:"white1On", icon:"st.illuminance.illuminance.dark", backgroundColor:"#cccccc"
state "on", label:"W1", action:"white1Off", icon:"st.illuminance.illuminance.bright", backgroundColor:"#FFFFFF"
controlTile("white1SliderControl", "device.white1Level", "slider", height: 1, width: 4, inactiveLabel: false) {
state "white1Level", action:"setWhite1Level"
valueTile("white1ValueTile", "device.white1Level", height: 1, width: 1) {
state "white1Level", label:'${currentValue}%'
standardTile("white2", "device.white2", height: 1, width: 1, inactiveLabel: false, decoration: "flat", canChangeIcon: false) {
state "off", label:"W2", action:"white2On", icon:"st.illuminance.illuminance.dark", backgroundColor:"#cccccc"
state "on", label:"W2", action:"white2Off", icon:"st.illuminance.illuminance.bright", backgroundColor:"#FFFFFF"
controlTile("white2SliderControl", "device.white2Level", "slider", height: 1, width: 4, inactiveLabel: false) {
state "white2Level", action:"setWhite2Level"
valueTile("white2ValueTile", "device.white2Level", height: 1, width: 1) {
state "white2Level", label:'${currentValue}%'
valueTile("ip", "ip", width: 2, height: 1) {
state "ip", label:'IP Address\r\n${currentValue}'
valueTile("firmware", "firmware", width: 2, height: 1) {
state "firmware", label:'Firmware ${currentValue}'
(1..6).each { n ->
standardTile("switch$n", "switch$n", canChangeIcon: true, width: 2, height: 2, decoration: "flat") {
state "off", label: "Program\n$n", action: "on$n", icon: "st.switches.switch.off", backgroundColor: "#cccccc"
state "on", label: "Program\n$n", action: "off$n", icon: "st.switches.switch.on", backgroundColor: "#00a0dc"
main(["switch"])
details(["switch", "levelSliderControl",
"red", "redSliderControl", "redValueTile",
"green", "greenSliderControl", "greenValueTile",
"blue", "blueSliderControl", "blueValueTile",
"white1", "white1SliderControl", "white1ValueTile",
"white2", "white2SliderControl", "white2ValueTile",
"switch1", "switch2", "switch3",
"switch4", "switch5", "switch6",
"refresh", "configure", "ip", "firmware" ])
def installed() {
log.debug "installed()"
configure()
def configure() {
logging("configure()", 1)
def cmds = []
cmds = update_needed_settings()
cmds << getAction("/info")
if (cmds != []) cmds
def updated()
logging("updated()", 1)
def cmds = []
sendEvent(name: "checkInterval", value: 12 * 60 * 2, data: [protocol: "lan", hubHardwareId: device.hub.hardwareID], displayed: false)
sendEvent(name:"needUpdate", value: device.currentValue("needUpdate"), displayed:false, isStateChange: true)
if (cmds != []) response(cmds)
private def logging(message, level) {
if (logLevel != "0"){
switch (logLevel) {
case "1":
if (level > 1)
log.debug "$message"
break
case "99":
break
def getDefault(){
if(settings.dcolor == "Previous") {
return "Previous"
} else if(settings.dcolor == "Random") {
return "${transition == "false"? "d~" : "f~"}${getHexColor(settings.dcolor)}"
} else if(settings.dcolor == "Custom" && settings.custom.length() == 10) {
//Here we have a 10 char value, i.e. exact colour choice
return "${settings.custom}"
} else if(settings.dcolor == "Custom" && settings.dcolor.length() != 10) {
return "${transition == "false"? "d~" : "f~"}${settings.custom}"
} else if(settings.dcolor == "Soft White" || settings.dcolor == "Warm White") {
if (settings.level == null || settings.level == "0") {
return "${transition == "false"? "x~" : "w~"}${getDimmedColor(getHexColor(settings.dcolor), "100")}"
} else {
return "${transition == "false"? "x~" : "w~"}${getDimmedColor(getHexColor(settings.dcolor), settings.level)}"
} else if(settings.dcolor == "W1") {
} else {
} else if(settings.dcolor == "W2") {
return "${transition == "false"? "z~" : "y~"}${getDimmedColor(getHexColor(settings.dcolor), "100")}"
} else {
return "${transition == "false"? "z~" : "y~"}${getDimmedColor(getHexColor(settings.dcolor), settings.level)}"
} else {
if (settings.level == null || settings.dcolor == null){
//Colour and level are null so default to previous
return "Previous"
} else if (settings.level == null || settings.level == "0") {
//Level is null or 0, so default to previous
return "${transition == "false"? "d~" : "f~"}${getDimmedColor(getHexColor(settings.dcolor), "100")}"
} else {
//Use custom Colour setting
return "${getDimmedColor(getHexColor(settings.dcolor), settings.level)}"
def parse(description) {
def map = [:]
def events = []
def cmds = []
if(description == "updated") return
def descMap = parseDescriptionAsMap(description)
if (descMap["mac"] != null && (!state.mac || state.mac != descMap["mac"])) {
log.debug "Mac address of device found ${descMap["mac"]}"
updateDataValue("mac", descMap["mac"])
state.mac = descMap["mac"]
if (state.mac != null && state.dni != state.mac) state.dni = setDeviceNetworkId(state.mac)
if (descMap["body"]) body = new String(descMap["body"].decodeBase64())
if (body && body != "") {
if(body.startsWith("{") || body.startsWith("[")) {
def slurper = new JsonSlurper()
def result = slurper.parseText(body)
if (result.containsKey("type")) {
if (result.type == "configuration")
events << update_current_properties(result)
if (result.containsKey("power")) {
events << createEvent(name: "switch", value: result.power)
toggleTiles("all")
if (result.containsKey("rgb")) {
events << createEvent(name:"color", value:"#$result.rgb")
def rgb = hexToRgb("#$result.rgb")
def hsv = rgbwToHSV(rgb)
events << createEvent(name:"hue", value:hsv.hue)
events << createEvent(name:"saturation", value:hsv.saturation)
// only store the previous value if the response did not come from a power-off command
if (result.power != "off")
state.previousRGB = result.rgb
if (result.containsKey("r")) {
events << createEvent(name:"redLevel", value: Integer.parseInt(result.r,16)/255 * 100 as Integer, displayed: false)
if ((Integer.parseInt(result.r,16)/255 * 100 as Integer) > 0 ) {
events << createEvent(name:"red", value: "on", displayed: false)
} else {
events << createEvent(name:"red", value: "off", displayed: false)
if (result.containsKey("g")) {
events << createEvent(name:"greenLevel", value: Integer.parseInt(result.g,16)/255 * 100 as Integer, displayed: false)
if ((Integer.parseInt(result.g,16)/255 * 100 as Integer) > 0 ) {
events << createEvent(name:"green", value: "on", displayed: false)
} else {
events << createEvent(name:"green", value: "off", displayed: false)
if (result.containsKey("b")) {
events << createEvent(name:"blueLevel", value: Integer.parseInt(result.b,16)/255 * 100 as Integer, displayed: false)
if ((Integer.parseInt(result.b,16)/255 * 100 as Integer) > 0 ) {
events << createEvent(name:"blue", value: "on", displayed: false)
} else {
events << createEvent(name:"blue", value: "off", displayed: false)
if (result.containsKey("w1")) {
events << createEvent(name:"white1Level", value: Integer.parseInt(result.w1,16)/255 * 100 as Integer, displayed: false)
if ((Integer.parseInt(result.w1,16)/255 * 100 as Integer) > 0 ) {
events << createEvent(name:"white1", value: "on", displayed: false)
} else {
events << createEvent(name:"white1", value: "off", displayed: false)
state.previousW1 = result.w1
if (result.containsKey("w2")) {
events << createEvent(name:"white2Level", value: Integer.parseInt(result.w2,16)/255 * 100 as Integer, displayed: false)
if ((Integer.parseInt(result.w2,16)/255 * 100 as Integer) > 0 ) {
events << createEvent(name:"white2", value: "on", displayed: false)
} else {
events << createEvent(name:"white2", value: "off", displayed: false)
state.previousW2 = result.w2
if (result.containsKey("version")) {
events << createEvent(name:"firmware", value: result.version + "\r\n" + result.date, displayed: false)
if (result.containsKey("success")) {
if (result.success == "true") state.configSuccess = "true" else state.configSuccess = "false"
if (result.containsKey("program")) {
if (result.running == "false") {
toggleTiles("all")
}else {
toggleTiles("switch$result.program")
events << createEvent(name:"switch$result.program", value: "on")
if (!device.currentValue("ip") || (device.currentValue("ip") != getDataValue("ip"))) events << createEvent(name: 'ip', value: getDataValue("ip"))
return events
private toggleTiles(value) {
def tiles = ["switch1", "switch2", "switch3", "switch4", "switch5", "switch6"]
tiles.each {tile ->
if (tile != value) sendEvent(name: tile, value: "off")
private getScaledColor(color) {
def rgb = color.findAll(/[0-9a-fA-F]{2}/).collect { Integer.parseInt(it, 16) }
def maxNumber = 1
for (int i = 0; i < 3; i++){
if (rgb[i] > maxNumber) {
maxNumber = rgb[i]
def scale = 255/maxNumber
rgb[i] = rgb[i] * scale
def myred = rgb[0]
def mygreen = rgb[1]
def myblue = rgb[2]
return rgbToHex([r:myred, g:mygreen, b:myblue])
def on() {
log.debug "on()"
getAction("/on?transition=$transition")
def off() {
log.debug "off()"
getAction("/off?transition=$transition")
def setLevel(level) {
setLevel(level, 1)
def setLevel(level, duration) {
log.debug "setLevel() level = ${level}"
if(level > 100) level = 100
if (level == 0) { off() }
else if (device.latestValue("switch") == "off") { on() }
sendEvent(name: "level", value: level)
sendEvent(name: "setLevel", value: level, displayed: false)
setColor(aLevel: level)
def setSaturation(percent) {
log.debug "setSaturation($percent)"
setColor(saturation: percent)
def setHue(value) {
log.debug "setHue($value)"
setColor(hue: value)
def getWhite(value) {
log.debug "getWhite($value)"
def level = Math.min(value as Integer, 99)
level = 255 * level/99 as Integer
log.debug "level: ${level}"
return hex(level)
def setColor(value) {
log.debug "setColor being called with ${value}"
def uri
def validValue = true
if ((value.saturation != null) && (value.hue != null)) {
def hue = (value.hue != null) ? value.hue : 13
def saturation = (value.saturation != null) ? value.saturation : 13
def rgb = huesatToRGB(hue as Integer, saturation as Integer)
value.hex = rgbToHex([r:rgb[0], g:rgb[1], b:rgb[2]])
if (value.hue == 5 && value.saturation == 4) {
log.debug "setting color Soft White - Default"
def whiteLevel = getWhite(value.level)
uri = "/w1?value=${whiteLevel}"
state.previousColor = "${whiteLevel}"
/* Letting White - Concentrate adjust RGB values
else if (value.hue == 63 && value.saturation == 28) {
log.debug "setting color White - Concentrate"
else if (value.hue == 63 && value.saturation == 43) {
log.debug "setting color Daylight - Energize"
uri = "/w2?value=${whiteLevel}"
else if (value.hue == 79 && value.saturation == 7) {
log.debug "setting color Warm White - Relax"
else if (value.colorTemperature) {
log.debug "setting color with color temperature"
else if (value.hex) {
log.debug "setting color with hex"
if (!value.hex ==~ /^\#([A-Fa-f0-9]){6}$/) {
log.debug "$value.hex is not valid"
validValue = false
} else {
def rgb = value.hex.findAll(/[0-9a-fA-F]{2}/).collect { Integer.parseInt(it, 16) }
def myred = rgb[0] < 40 ? 0 : rgb[0]
def mygreen = rgb[1] < 40 ? 0 : rgb[1]
def myblue = rgb[2] < 40 ? 0 : rgb[2]
def dimmedColor = getDimmedColor(rgbToHex([r:myred, g:mygreen, b:myblue]))
uri = "/rgb?value=${dimmedColor}"
else if (value.white) {
uri = "/w1?value=${value.white}"
else if (value.aLevel) {
def actions = []
if (channels == "true") {
def skipColor = false
// Handle white channel dimmers if they're on or were not previously off (excluding power-off command)
if (device.currentValue("white1") == "on" || state.previousW1 != "00") {
actions.push(setWhite1Level(value.aLevel))
skipColor = true
if (device.currentValue("white2") == "on" || state.previousW2 != "00") {
actions.push(setWhite2Level(value.aLevel))
skipColor = true
if (skipColor == false) {
log.debug state.previousRGB
// if the device is currently on, scale the current RGB values; otherwise scale the previous setting
uri = "/rgb?value=${getDimmedColor(device.latestValue("switch") == "on" ? device.currentValue("color").substring(1) : state.previousRGB)}"
actions.push(getAction("$uri&channels=$channels&transition=$transition"))
} else {
return actions
else {
// A valid color was not chosen. Setting to white
uri = "/w1?value=ff"
if (uri != null && validValue != false) getAction("$uri&channels=$channels&transition=$transition")
private getDimmedColor(color, level) {
if(color.size() > 2){
def scaledColor = getScaledColor(color)
def rgb = scaledColor.findAll(/[0-9a-fA-F]{2}/).collect { Integer.parseInt(it, 16) }
def r = hex(rgb[0] * (level.toInteger()/100))
def g = hex(rgb[1] * (level.toInteger()/100))
def b = hex(rgb[2] * (level.toInteger()/100))
return "${r + g + b}"
}else{
color = Integer.parseInt(color, 16)
return hex(color * (level.toInteger()/100))
private getDimmedColor(color) {
if (device.latestValue("level")) {
getDimmedColor(color, device.latestValue("level"))
} else {
return color.replaceAll("#","")
def reset() {
log.debug "reset()"
setColor(white: "ff")
def refresh() {
log.debug "refresh()"
getAction("/status")
def ping() {
log.debug "ping()"
refresh()
def setWhiteLevel(value) {
log.debug "setwhiteLevel: ${value}"
if ( value > 0 ) {
sendEvent(name: "white", value: "on")
} else {
sendEvent(name: "white", value: "off")
def whiteLevel = hex(level)
setColor(white: whiteLevel)
def hexToRgb(colorHex) {
def rrInt = Integer.parseInt(colorHex.substring(1,3),16)
def ggInt = Integer.parseInt(colorHex.substring(3,5),16)
def bbInt = Integer.parseInt(colorHex.substring(5,7),16)
def colorData = [:]
colorData = [r: rrInt, g: ggInt, b: bbInt]
colorData
// huesatToRGB Changed method provided by daved314
def huesatToRGB(float hue, float sat) {
if (hue <= 100) {
hue = hue * 3.6
sat = sat / 100
float v = 1.0
float c = v * sat
float x = c * (1 - Math.abs(((hue/60)%2) - 1))
float m = v - c
int mod_h = (int)(hue / 60)
int cm = Math.round((c+m) * 255)
int xm = Math.round((x+m) * 255)
int zm = Math.round((0+m) * 255)
switch(mod_h) {
case 0: return [cm, xm, zm]
case 1: return [xm, cm, zm]
case 2: return [zm, cm, xm]
case 3: return [zm, xm, cm]
case 4: return [xm, zm, cm]
case 5: return [cm, zm, xm]
private rgbwToHSV(Map colorMap) {
log.debug "rgbwToHSV(): colorMap: ${colorMap}"
if (colorMap.containsKey("r") & colorMap.containsKey("g") & colorMap.containsKey("b")) {
float r = colorMap.r / 255f
float g = colorMap.g / 255f
float b = colorMap.b / 255f
float w = (colorMap.white) ? colorMap.white / 255f : 0.0
float max = [r, g, b].max()
float min = [r, g, b].min()
float delta = max - min
float h,s,v = 0
if (delta) {
s = delta / max
if (r == max) {
h = ((g - b) / delta) / 6
} else if (g == max) {
h = (2 + (b - r) / delta) / 6
} else {
h = (4 + (r - g) / delta) / 6
while (h < 0) h += 1
while (h >= 1) h -= 1
v = [max,w].max()
return colorMap << [ hue: h * 100, saturation: s * 100, level: Math.round(v * 100) ]
else {
log.error "rgbwToHSV(): Cannot obtain color information from colorMap: ${colorMap}"
private hex(value, width=2) {
def s = new BigInteger(Math.round(value).toString()).toString(16)
while (s.size() < width) {
s = "0" + s
s
def rgbToHex(rgb) {
def r = hex(rgb.r)
def g = hex(rgb.g)
def b = hex(rgb.b)
def hexColor = "#${r}${g}${b}"
hexColor
def sync(ip, port) {
def existingIp = getDataValue("ip")
def existingPort = getDataValue("port")
if (ip && ip != existingIp) {
updateDataValue("ip", ip)
sendEvent(name: 'ip', value: ip)
if (port && port != existingPort) {
updateDataValue("port", port)
private encodeCredentials(username, password){
def userpassascii = "${username}:${password}"
def userpass = "Basic " + userpassascii.encodeAsBase64().toString()
return userpass
private getAction(uri){
updateDNI()
def userpass
log.debug uri
if(password != null && password != "")
userpass = encodeCredentials("admin", password)
def headers = getHeader(userpass)
def hubAction = new hubitat.device.HubAction(
method: "GET",
path: uri,
headers: headers
return hubAction
private postAction(uri, data){
updateDNI()
def userpass
method: "POST",
path: uri,
headers: headers,
body: data
return hubAction
private setDeviceNetworkId(ip, port = null){
def myDNI
if (port == null) {
myDNI = ip
} else {
def iphex = convertIPtoHex(ip)
def porthex = convertPortToHex(port)
myDNI = "$iphex:$porthex"
log.debug "Device Network Id set to ${myDNI}"
return myDNI
private updateDNI() {
if (state.dni != null && state.dni != "" && device.deviceNetworkId != state.dni) {
device.deviceNetworkId = state.dni
private getHostAddress() {
if(getDeviceDataByName("ip") && getDeviceDataByName("port")){
return "${getDeviceDataByName("ip")}:${getDeviceDataByName("port")}"
}else{
return "${ip}:80"
private String convertIPtoHex(ipAddress) {
String hex = ipAddress.tokenize( '.' ).collect { String.format( '%02x', it.toInteger() ) }.join()
return hex
private String convertPortToHex(port) {
String hexport = port.toString().format( '%04x', port.toInteger() )
return hexport
private getHeader(userpass = null){
def headers = [:]
headers.put("Host", getHostAddress())
headers.put("Content-Type", "application/x-www-form-urlencoded")
if (userpass != null)
headers.put("Authorization", userpass)
return headers
def toAscii(s){
StringBuilder sb = new StringBuilder();
String ascString = null;
long asciiInt;
for (int i = 0; i < s.length(); i++){
sb.append((int)s.charAt(i));
sb.append("|");
char c = s.charAt(i);
ascString = sb.toString();
asciiInt = Long.parseLong(ascString);
return asciiInt;
def on1() { onOffCmd(1, 1) }
def on2() { onOffCmd(1, 2) }
def on3() { onOffCmd(1, 3) }
def on4() { onOffCmd(1, 4) }
def on5() { onOffCmd(1, 5) }
def on6() { onOffCmd(1, 6) }
def off1(p=null) { onOffCmd((p == null ? 0 : p), 1) }
def off2(p=null) { onOffCmd((p == null ? 0 : p), 2) }
def off3(p=null) { onOffCmd((p == null ? 0 : p), 3) }
def off4(p=null) { onOffCmd((p == null ? 0 : p), 4) }
def off5(p=null) { onOffCmd((p == null ? 0 : p), 5) }
def off6(p=null) { onOffCmd((p == null ? 0 : p), 6) }
def onOffCmd(value, program) {
log.debug "onOffCmd($value, $program)"
def uri
if (value == 1){
if(state."program${program}" != null) {
uri = "/program?value=${state."program${program}"}&number=$program"
} else if(value == 0){
uri = "/stop"
} else {
uri = "/off"
log.debug uri
if (uri != null) return getAction(uri)
def setProgram(value, program){
state."program${program}" = value
def hex2int(value){
return Integer.parseInt(value, 10)
def redOn() {
log.debug "redOn()"
getAction("/r?value=ff&channels=$channels&transition=$transition")
def redOff() {
log.debug "redOff()"
getAction("/r?value=00&channels=$channels&transition=$transition")
def setRedLevel(value) {
log.debug "setRedLevel: ${value}"
level = hex(level)
getAction("/r?value=$level&channels=$channels&transition=$transition")
def greenOn() {
log.debug "greenOn()"
getAction("/g?value=ff&channels=$channels&transition=$transition")
def greenOff() {
log.debug "greenOff()"
getAction("/g?value=00&channels=$channels&transition=$transition")
def setGreenLevel(value) {
log.debug "setGreenLevel: ${value}"
level = hex(level)
getAction("/g?value=$level&channels=$channels&transition=$transition")
def blueOn() {
log.debug "blueOn()"
getAction("/b?value=ff&channels=$channels&transition=$transition")
def blueOff() {
log.debug "blueOff()"
getAction("/b?value=00&channels=$channels&transition=$transition")
def setBlueLevel(value) {
log.debug "setBlueLevel: ${value}"
level = hex(level)
getAction("/b?value=$level&channels=$channels&transition=$transition")
def white1On() {
log.debug "white1On()"
getAction("/w1?value=ff&channels=$channels&transition=$transition")
def white1Off() {
log.debug "white1Off()"
getAction("/w1?value=00&channels=$channels&transition=$transition")
def setWhite1Level(value) {
log.debug "setwhite1Level: ${value}"
getAction("/w1?value=$whiteLevel&channels=$channels&transition=$transition")
def white2On() {
log.debug "white2On()"
getAction("/w2?value=ff&channels=$channels&transition=$transition")
def white2Off() {
log.debug "white2Off()"
getAction("/w2?value=00&channels=$channels&transition=$transition")
def setWhite2Level(value) {
log.debug "setwhite2Level: ${value}"
getAction("/w2?value=$whiteLevel&channels=$channels&transition=$transition")
private getHexColor(value){
def color = ""
switch(value){
case "Previous":
color = "Previous"
break;
case "White":
color = "ffffff"
break;
case "Daylight":
color = "ffffff"
break;
case "Soft White":
color = "ff"
break;
case "Warm White":
color = "ff"
break;
case "W1":
color = "ff"
break;
case "W2":
color = "ff"
break;
case "Blue":
color = "0000ff"
break;
case "Green":
color = "00ff00"
break;
case "Yellow":
color = "ffff00"
break;
case "Orange":
color = "ff5a00"
break;
case "Purple":
color = "5a00ff"
break;
case "Pink":
color = "ff00ff"
break;
case "Cyan":
color = "00ffff"
break;
case "Red":
color = "ff0000"
break;
case "Off":
color = "000000"
break;
case "Random":
color = "xxxxxx"
break;
return color
def generate_preferences(configuration_model)
def configuration = new XmlSlurper().parseText(configuration_model)
configuration.Value.each
if(it.@hidden != "true" && it.@disabled != "true"){
switch(it.@type)
case ["number"]:
input "${it.@index}", "number",
title:"${it.@label}\n" + "${it.Help}",
range: "${it.@min}..${it.@max}",
defaultValue: "${it.@value}",
displayDuringSetup: "${it.@displayDuringSetup}"
break
case "list":
def items = []
it.Item.each { items << ["${it.@value}":"${it.@label}"] }
input "${it.@index}", "enum",
displayDuringSetup: "${it.@displayDuringSetup}",
options: items
break
case ["password"]:
input "${it.@index}", "password",
break
case "decimal":
input "${it.@index}", "decimal",
break
case "boolean":
input "${it.@index}", "boolean",
break
case "text":
input "${it.@index}", "text",
break
/* Code has elements from other community source @CyrilPeponnet (Z-Wave Parameter Sync). */
def update_current_properties(cmd)
def currentProperties = state.currentProperties ?: [:]
currentProperties."${cmd.name}" = cmd.value
if (settings."${cmd.name}" != null)
if (convertParam("${cmd.name}", settings."${cmd.name}").toString() == cmd.value)
sendEvent(name:"needUpdate", value:"NO", displayed:false, isStateChange: true)
else
sendEvent(name:"needUpdate", value:"YES", displayed:false, isStateChange: true)
state.currentProperties = currentProperties
def update_needed_settings()
def cmds = []
def configuration = new XmlSlurper().parseText(configuration_model())
def isUpdateNeeded = "NO"
cmds << getAction("/configSet?name=haip&value=${device.hub.getDataValue("localIP")}")
cmds << getAction("/configSet?name=haport&value=${device.hub.getDataValue("localSrvPortTCP")}")
if ("${it.@setting_type}" == "lan" && it.@disabled != "true"){
if (currentProperties."${it.@index}" == null)
if (it.@setonly == "true"){
logging("Setting ${it.@index} will be updated to ${convertParam("${it.@index}", it.@value)}", 2)
cmds << getAction("/configSet?name=${it.@index}&value=${convertParam("${it.@index}", it.@value)}")
} else {
isUpdateNeeded = "YES"
logging("Current value of setting ${it.@index} is unknown", 2)
cmds << getAction("/configGet?name=${it.@index}")
else if ((settings."${it.@index}" != null || it.@hidden == "true") && currentProperties."${it.@index}" != (settings."${it.@index}"? convertParam("${it.@index}", settings."${it.@index}".toString()) : convertParam("${it.@index}", "${it.@value}")))
logging("Setting ${it.@index} will be updated to ${convertParam("${it.@index}", settings."${it.@index}")}", 2)
cmds << getAction("/configSet?name=${it.@index}&value=${convertParam("${it.@index}", settings."${it.@index}")}")
sendEvent(name:"needUpdate", value: isUpdateNeeded, displayed:false, isStateChange: true)
return cmds
def convertParam(name, value) {
switch (name){
case "dcolor":
getDefault()
break
default:
value
break
def configuration_model()
<configuration>
<Value type="password" byteSize="1" index="password" label="Password" min="" max="" value="" setting_type="preference" fw="">
<Help>
</Help>
</Value>
<Value type="list" byteSize="1" index="pos" label="Boot Up State" min="0" max="2" value="0" setting_type="lan" fw="">
<Help>
Default: Off
</Help>
<Item label="Off" value="0" />
<Item label="On" value="1" />
</Value>
<Value type="list" byteSize="1" index="transition" label="Default Transition" min="0" max="1" value="0" setting_type="preference" fw="">
<Help>
Default: Fade
</Help>
<Item label="Fade" value="true" />
<Item label="Flash" value="false" />
</Value>
<Value type="list" byteSize="1" index="dcolor" label="Default Color" min="" max="" value="" setting_type="lan" fw="">
<Help>
Default: Previous
</Help>
<Item label="Previous" value="Previous" />
<Item label="Soft White - Default" value="Soft White" />
<Item label="White - Concentrate" value="White" />
<Item label="Daylight - Energize" value="Daylight" />
<Item label="Warm White - Relax" value="Warm White" />
<Item label="Red" value="Red" />
<Item label="Green" value="Green" />
<Item label="Blue" value="Blue" />
<Item label="Yellow" value="Yellow" />
<Item label="Orange" value="Orange" />
<Item label="Purple" value="Purple" />
<Item label="Pink" value="Pink" />
<Item label="Cyan" value="Random" />
<Item label="W1" value="W1" />
<Item label="W2" value="W2" />
<Item label="Custom" value="Custom" />
</Value>
<Value type="text" byteSize="1" index="custom" label="Custom Color in Hex - RRGGBBW1W2" min="" max="" value="" setting_type="preference" fw="">
<Help>
e.g. FF00008080 would be Red at 100% and W1+W2 at 50%
If \"Custom\" is chosen above as the default color. Default level does not apply if custom hex value is chosen.
</Help>
</Value>
<Value type="number" byteSize="1" index="level" label="Default Level" min="1" max="100" value="" setting_type="preference" fw="">
<Help>
</Help>
</Value>
<Value type="boolean" byteSize="1" index="channels" label="Mutually Exclusive RGB / White.\nOnly allow one or the other" min="" max="" value="false" setting_type="preference" fw="">
<Help>
</Help>
</Value>
<Value type="list" byteSize="1" index="transitionspeed" label="Transition Speed" min="1" max="3" value="1" setting_type="lan" fw="">
<Help>
Default: Slow
</Help>
<Item label="Slow" value="1" />
<Item label="Medium" value="2" />
<Item label="Fast" value="3" />
</Value>
<Value type="number" byteSize="1" index="autooff" label="Auto Off" min="0" max="65536" value="0" setting_type="lan" fw="" disabled="true">
<Help>
Automatically turn the switch off after this many seconds.
Range: 0 to 65536
Default: 0 (Disabled)
</Help>
</Value>
<Value type="list" index="logLevel" label="Debug Logging Level?" value="0" setting_type="preference" fw="">
<Help>
</Help>
<Item label="None" value="0" />
<Item label="Reports" value="1" />
<Item label="All" value="99" />
</Value>
</configuration>
Thanks a lot @cuboy29 .
Evaluating now.
