Migrated to C8-Pro - Cloud Network strangeness
@support_team
Migrated ~5 days ago with mostly no issues. Took me roughly 45 minutes start to finish and all appears to be working well.
Hub Details and Version information - C8-Pro, Ethernet connected directly to the router - latest platform version - getting proper Sunrise / Sunset
I moved my Hub Protect Subscription, and can do cloud backups no issue. I went to go and deregister my old hub and saw something odd:
My Subscriptions Page - Shows hub as offine
I have no "cloud not available warning" on the hubitat itself. All externally facing apps; Google Home, Alexa, Google SDMI, MakerAPI, and Cloud dashboards work fine.
In the HubInfo Driver, it shows:
Invalid Endpoint for the cloud connection
I have already done the following:
-Standard Reboot
-Power Down From the settings, disconnect power for 45 seconds, plug back in
-Held the network reset and waited for reboot
-Verified that the hubID and Mac shown on the "hub details" page match on the hub and the "my registered hubs" page.
Verified no blocked flows on firewall for the Hubitat
Successfully Pinged Cloud dot Hubitat dot com from the network test on hubitat
-The old hub is off and has not been on since I took the backup just before a final shut down. It also has a different reserved address should I connect it back already. It just shows the last IP it had before I shut it down.
While I am not overly concerned since everything is working, I am wondering what else I could/should check and if it is anything I should be worried about. I do know that it did show online when I initially registered the new hub.
*** Edited to add,
DNS is coming from router and Well known DNS services to be used as fallback is selected
One more bit of information, the hub appears to be checking in. The last checkin was between the original post time and the time of this follow up message. Cloud dasboard link on that page also works.
I fixed the hub info driver, which now shows connected by adding a current cloud dashboard URL. However, it still shows as offline in the registered hubs page.
Okay, some weirdness with not immediately deregistering the old hub seems to be the issue. I deregistered the old hub, then ran a cloud backup (successfully), got a brief "cloud connection unavailable" message, and then went to look at registered hubs. It still said offline. But, the last checkin updated to the time when I performed the back up.
After waiting a few more minutes, I refreshed the page, and it now shows online.
**** Edited to add, after a few more minutes, it went back to saying it was offline again. Still all external services work, cloud endpoints work, and no alert message on the hub itself... so back to the drawing board.******
@bobbyD - is this expected behavior? If so, should it be mentioned in the migration steps as a note at least? (also, if so, is it only when you assign it the same IP reservation? - See this thread here - C8 > C8-Pro. Everything is fine - except Hub says no Cloud Connection - #5 by lflorack1)
Tagging @support_team and/or @bobbyD again. This issue is still occuring.
The page doesn't refresh automatically, so the status can be out of sync. As for the offline notification, we report what we see.
So, is it a non-issue then? I don't recall ever seeing my C7 offline. But, I admittedly did not check it frequently. I only noticed when I went to deregister it? (My main concern is more on the order of your ability to get to the engineering logs at a later point if needed - As I said, everything cloud related appears to be working)
