Hello. I have a small problem. I bought projectors from Miboxer model FUTC05Z and unfortunately HE does not want to find it and add it. Can someone help me with this problem?
Thanks!
its not showing up on List of Compatible Devices | Hubitat Documentation
Make sure the light is near the hub
Start the pairing process on hubitat hub
Start the pairing process on the light (light is breathing, if not turn off and on 3 times)
let the paring process run on hubitat
if its not paired post the logs and someone might be able to help.
