Mi Air Fryer
My main uses are preheating from another room, changing temperature to crisp things towards the end and notifying me to shake during cooking. Also keeping track of timing (eg notifying me when the cycle finishes).
A mixture of pain medication and mobility issues make an integrated cooking facility very useful. A measure of caution is always helpful but the benefits certainly outweigh the relatively minor risk in my case.
Good points. Are you using the same air fryer? The op’s doesn’t seem to have those capabilities. At least not with the HA integration.
I'm using a Proscenic T21, it's currently managed using a branded app via their servers but having done some research after seeing this thread I'll be converting it to Tasmota (hardware swap, replace the WiFi board with an ESP32) which will enable full local control via home assistant.
thanks for your response.
Actually, what I need is an Alexa command to do these (with priority order):
  1. ask for remaining cooking time
  2. ask to pause cooking (with original Mi home integration, I am able to start/stop but I need a pause)
  3. ask to change target cooking temperature
  4. ask to change target cooking time
These can be adjusted through HA. But up to now "target cooking time" and "remaining cooking time" was not created on Hubitat. I need to figure out a way to force it updated maybe.
Also, at first when you told me to install HA and do the integration through it, I had thought that it would create a "Air Fryer" device on Hubitat (and Alexa) that I would be able to control all features through it.
Now I understand that I will receive several entities from HA and will only be able to control them individually as separate devices. That's interesting.
Please tell me if I understood correct or not...
Btw, happy new year to all the Hubitat community :smiley:
Happy New Year!
You understand correctly now. The way this integration works is it creates a device on your Hubitat hub for a matching Home Assistant equivalent to one of the Hubitat Generic Component drivers, in other words, for this to work, the device you want to import has to creat an “entity” on Home Assistant, and there has to be a Generic Component driver of that entity type on HE.
“Air Fryer” would be too generic of an entity, since it would only describe what the device is, not the individual capabilities of the device.
I've played a little bit with the HA
I even integrated it directly with Alexa using AWS Lambda service and a custom Alexa skill.
But finally I decided to remove HomeAssistant.
It's entity based structure is not good for me.
Even if I directly integrate it with Alexa (removing Hubitat from the flow) I have to use separate virtual devices to control each feature (target temp, target duration, remaining duration, status of device, recipe ID)
A normal kitchen appliance integration shouldn't be like this. There are robust and good Alexa integrations where Alexa identifies the device as a kitchen appliance and controls all features through a single device name.
(eg. set target temperature 200 on air fryer)
Well that’s good you found a solution that works for you.
If you want HE to control one of the features, you could do it via the Alexa integration and a small bit of code on HE that makes a switch act like a contact or motion sensor. This can trigger an Alexa routine when your virtual “contact” closes.
Alexa routines now allow you to create custom actions. In other words, anything you would say to trigger a device can be initiated from a routine instead.
