I installed a switch in master bathroom to turn on and off my hot water circulator. I set up the rules. Did exactly same procedure in my casita. I added a plug repeater in master bedroom. It works in casita but not in master bath. I checked and plug mesh is enable. Any ideas?
What are the actual brand and models of the devices involved? It sounds like you are talkng about Lutron Caséta or perhaps some combination of Caséta devices and some other kind, but it's not clear from the above.
It also sounds like you are confusing the purpose of the "Hub mesh enabled" option with something else. It is related only to the Hub Mesh feature that allows sharing devices among multiple hubs over your LAN (if you have more than one hub). It does not have anything to do with Z-Wave or Zigbee meshes (or Caséta, which isn't quite a mesh but does allow an extender or two).
I think this is referring to a room (or a shed/outbuilding/guest house), not Lutron Caseta.
I agree that more details would be helpful though.
Casita is like a small guest house. Casita means little house. Example of rule I used.
Basic Rule
When Master shower turns off ... Turn off Water heater
When a ...
Does this
Do this action:
Can you please explain more what you mean by "plug mesh is enabled"?
Continuing the discussion from Mesh Network:
Used the same basic rule for both switches. I added a plug repeater for both. Where is the best place to place the plug repeater? I tried in master bedroom. Halfway between hub and switch.
This would still be helpful to know:
