Menu Gear, + and check mark
I know the green check mark at the top of the menu is necessary to refresh I would prefer that the + and the gear symbol next to the check not be available to anyone who walks up to one of my kindles running that menu. Is there a way to set the menu so they do not appear? I looked at the menu in the Apps section but don't see any setting like that and a search here did not offer any suggestions unless I am just not searching right.
I assume your question is related to Hubitat Dashboard, since your description of the UI matches up with the default UI of Dashboard.
In that case, it sounds like you're looking for the "Lock down dashboard so no changes can be made in the web UI of this dashboard" option. This is located under Apps > Hubitat Dashboard, then the "child app" for the particular dashboard in question. You'll have to look under the "Advanced" heading to see this. Note that this is, again, under "Apps," not "Dashboards," and we're talking about the regular hub admin UI, not the mobile app (though you can use the mobile app to get there if you really want to).
Thanks for the quick response. Yes, the Hubitat Dashboard. I had looked in the Apps section under the particular dashboard but did not go to the child app area. Thanks for the tip and I should be able to figure it out from there. Appreciate the help.
I found the switch for the lockdown feature and that is exactly what I was looking for (and missed).
