Good morning,
i have a hubitat c8, it worked fine in last year with integration with home assistant. Now it is burning memory even with almost all app's and devices unistalled.
What do the logs say? Any warnings or errors? Also check Devices and Apps Stats for clues.
it only alertยดs for load.. too much load.
the informations on log is the same. can't see what device or app is cousing the problem
The past logs tab should give you the information necessary to determine which device is causing the increased load.
Or also check the Device / Apps stats pages to find clues.
