hi trying to setup my 3 botton MCO Touch Panel i download the from the wiki it then says that i need to add another file not sure what they mean when they say i need both files ,if past it to the bottom if the first one i get a error
They are 2 different drivers and need to be save individually.
do i need to piont my device to the 2nd one if so where do i do that
You should only need to select the parent driver and it will then use the child driver to create the child devices .
will try tonight
thanks i got it 1/2 working just trying to work out why the child devices don't report the state of the switch
