Not sure what I am looking at here. The Ikea contact is offline in HE but working in Apple. I cleared the matter logs. Then cycled the contact several times with it not responding in HE. Then downloaded the logs. Gonna try to upload the log file and maybe someone else can see what I should be looking for. Well here is part of it anyway.
[1166:1268] Found matching exchange: 62307r, Delegate: (nil)
[1166:1268] Rxd Ack; Removing MessageCounter:121399875 from Retrans Table on exchange 62307r
[1166:1268] >>> [E:62311r S:52782 M:165187649] (S) Msg RX from 1:0000000000000C09 [A31D] to 000000000001B669 --- Type 0001:05 (IM:ReportData) (B:41)
[1166:1268] Handling via exchange: 62311r, Delegate: 0x7f737f8fe0
[1166:1268] ReportDataMessage =
[1166:1268] {
[1166:1268] SubscriptionId = 0xf900007f,
[1166:1268] InteractionModelRevision = 1
[1166:1268] }
[1166:1268] Refresh LivenessCheckTime for 22082 milliseconds with SubscriptionId = 0xf900007f Peer = 01:0000000000000C09
[1166:1268] <<< [E:62311r S:52782 M:121399876 (Ack:165187649)] (S) Msg TX from 000000000001B669 to 1:0000000000000C09 [A31D] [UDP:[fe80::2abb:edff:fe88:1c53%eth0]:5540] --- Type 0001:01 (IM:StatusResponse) (B:42)
[1166:1268] ??1 [E:62311r S:52782 M:121399876] (S) Msg Retransmission to 1:0000000000000C09 scheduled for 558ms from now [State:Active II:5300 AI:500 AT:300]
[1166:1268] >>> [E:62311r S:52782 M:165187650 (Ack:121399876)] (S) Msg RX from 1:0000000000000C09 [A31D] to 000000000001B669 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
[1166:1268] Found matching exchange: 62311r, Delegate: (nil)
[1166:1268] Rxd Ack; Removing MessageCounter:121399876 from Retrans Table on exchange 62311r
[1166:1268] >>> [E:62315r S:52782 M:165187651] (S) Msg RX from 1:0000000000000C09 [A31D] to 000000000001B669 --- Type 0001:05 (IM:ReportData) (B:41)
[1166:1268] Handling via exchange: 62315r, Delegate: 0x7f737f8fe0
[1166:1268] {
[1166:1268] }
[1166:1268] <<< [E:62315r S:52782 M:121399877 (Ack:165187651)] (S) Msg TX from 000000000001B669 to 1:0000000000000C09 [A31D] [UDP:[fe80::2abb:edff:fe88:1c53%eth0]:5540] --- Type 0001:01 (IM:StatusResponse) (B:42)
[1166:1268] ??1 [E:62315r S:52782 M:121399877] (S) Msg Retransmission to 1:0000000000000C09 scheduled for 565ms from now [State:Active II:5300 AI:500 AT:300]
[1166:1268] >>> [E:62315r S:52782 M:165187652 (Ack:121399877)] (S) Msg RX from 1:0000000000000C09 [A31D] to 000000000001B669 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
[1166:1268] Found matching exchange: 62315r, Delegate: (nil)
[1166:1268] Rxd Ack; Removing MessageCounter:121399877 from Retrans Table on exchange 62315r
[1166:1268] >>> [E:4193r S:52824 M:108585420] (S) Msg RX from 1:0000000000000C6A [A31D] to 000000000001B669 --- Type 0001:05 (IM:ReportData) (B:95)
[1166:1268] Handling via exchange: 4193r, Delegate: 0x7f737f8fe0
[1166:1268] SubscriptionId = 0xf998ed04,
[1166:1268] AttributeReportIBs =
[1166:1268] [
[1166:1268] DataVersion = 0x30d9c851,
[1166:1268] Endpoint = 0x0,
[1166:1268] Cluster = 0x2f,
[1166:1268] Attribute = 0x0000_000C,
[1166:1268] Data = 184 (unsigned),
[1166:1268] AttributeReportIB =
[1166:1268] AttributeDataIB =
[1166:1268] DataVersion = 0x9c4c980b,
[1166:1268] AttributePathIB =
[1166:1268] {
[1166:1268] Endpoint = 0x1,
[1166:1268] Cluster = 0x45,
[1166:1268] Attribute = 0x0000_0000,
[1166:1268] }
[1166:1268]
[1166:1268] Data = true,
[1166:1268] },
[1166:1268] },
[1166:1268] ],
[1166:1268]
[1166:1268] InteractionModelRevision = 12
[1781218279.191] [1166:1268] [DMG] }
put : 12, status Success, clusterStatus None
put : 0, status Success, clusterStatus None
[1166:1268] Refresh LivenessCheckTime for 1844277 milliseconds with SubscriptionId = 0xf998ed04 Peer = 01:0000000000000C6A
[1166:1268] <<< [E:4193r S:52824 M:57292096 (Ack:108585420)] (S) Msg TX from 000000000001B669 to 1:0000000000000C6A [A31D] [UDP:[fdcd:57ad:6f64:0:b888:c708:f06a:40a5]:5540] --- Type 0001:01 (IM:StatusResponse) (B:42)
[1166:1268] ??1 [E:4193r S:52824 M:57292096] (S) Msg Retransmission to 1:0000000000000C6A scheduled for 3100ms from now [State:Active II:17000 AI:2500 AT:1000]
[1166:1268] >>> [E:4195r S:52824 M:108585421] (S) Msg RX from 1:0000000000000C6A [A31D] to 000000000001B669 --- Type 0001:05 (IM:ReportData) (B:95)
[1166:1268] Handling via exchange: 4195r, Delegate: 0x7f737f8fe0
[1166:1268] SubscriptionId = 0x8ec8c2c2,
[1166:1268] [
[1166:1268] {
[1166:1268] },
[1166:1268] ],
[1166:1268]
[1166:1268] }
[1166:1268] Received report with invalid subscriptionId 2395521730
[1166:1268] <<< [E:4195r S:52824 M:57292097 (Ack:108585421)] (S) Msg TX from 000000000001B669 to 1:0000000000000C6A [A31D] [UDP:[fdcd:57ad:6f64:0:b888:c708:f06a:40a5]:5540] --- Type 0001:01 (IM:StatusResponse) (B:42)
[1166:1268] ??1 [E:4195r S:52824 M:57292097] (S) Msg Retransmission to 1:0000000000000C6A scheduled for 2793ms from now [State:Active II:17000 AI:2500 AT:1000]
[1166:1268] >>> [E:4196r S:52824 M:108585422] (S) Msg RX from 1:0000000000000C6A [A31D] to 000000000001B669 --- Type 0001:05 (IM:ReportData) (B:95)
[1166:1268] Handling via exchange: 4196r, Delegate: 0x7f737f8fe0
[1166:1268] SubscriptionId = 0x9b60999b,
[1166:1268] [
[1166:1268] {
[1166:1268] }
[1166:1268] },
[1166:1268] ],
[1166:1268]
[1166:1268] }
[1166:1268] Received report with invalid subscriptionId 2606799259
[1166:1268] <<< [E:4196r S:52824 M:57292098 (Ack:108585422)] (S) Msg TX from 000000000001B669 to 1:0000000000000C6A [A31D] [UDP:[fdcd:57ad:6f64:0:b888:c708:f06a:40a5]:5540] --- Type 0001:01 (IM:StatusResponse) (B:42)
[1166:1268] ??1 [E:4196r S:52824 M:57292098] (S) Msg Retransmission to 1:0000000000000C6A scheduled for 2990ms from now [State:Active II:17000 AI:2500 AT:1000]
[1166:1268] >>> [E:4197r S:52824 M:108585423] (S) Msg RX from 1:0000000000000C6A [A31D] to 000000000001B669 --- Type 0001:05 (IM:ReportData) (B:95)
[1166:1268] Handling via exchange: 4197r, Delegate: 0x7f737f8fe0
[1166:1268] {
[1166:1268] SubscriptionId = 0xfa9706d,
[1166:1268] [
[1166:1268] {
[1166:1268] },
[1166:1268] ],
[1166:1268]
[1166:1268] }
[1166:1268] Received report with invalid subscriptionId 262762605
[1166:1268] <<< [E:4197r S:52824 M:57292099 (Ack:108585423)] (S) Msg TX from 000000000001B669 to 1:0000000000000C6A [A31D] [UDP:[fdcd:57ad:6f64:0:b888:c708:f06a:40a5]:5540] --- Type 0001:01 (IM:StatusResponse) (B:42)
[1166:1268] ??1 [E:4197r S:52824 M:57292099] (S) Msg Retransmission to 1:0000000000000C6A scheduled for 2947ms from now [State:Active II:17000 AI:2500 AT:1000]
[1166:1268] Received a duplicate message with MessageCounter:108585420 on exchange 4193r
[1166:1268] Found matching exchange: 4193r, Delegate: (nil)
[1166:1268] Forcing tx of solitary ack for duplicate MessageCounter:108585420 on exchange 4193r
[1166:1268] <<< [E:4193r S:52824 M:57292100 (Ack:108585420)] (S) Msg TX from 000000000001B669 to 1:0000000000000C6A [A31D] [UDP:[fdcd:57ad:6f64:0:b888:c708:f06a:40a5]:5540] --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
[1166:1268] Received a duplicate message with MessageCounter:108585422 on exchange 4196r
[1166:1268] Found matching exchange: 4196r, Delegate: (nil)
[1166:1268] Forcing tx of solitary ack for duplicate MessageCounter:108585422 on exchange 4196r
[1166:1268] <<< [E:4196r S:52824 M:57292101 (Ack:108585422)] (S) Msg TX from 000000000001B669 to 1:0000000000000C6A [A31D] [UDP:[fdcd:57ad:6f64:0:b888:c708:f06a:40a5]:5540] --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
[1166:1268] Received a duplicate message with MessageCounter:108585421 on exchange 4195r
[1166:1268] Found matching exchange: 4195r, Delegate: (nil)
[1166:1268] Forcing tx of solitary ack for duplicate MessageCounter:108585421 on exchange 4195r
