Matter provisioning issue
Level Bolt lock, first connected to Level app, then Home, then Hubitat. First one went great, actually have it in two different Hubitat hubs. Second lock, not so lucky. Get new code from Home, enter it into and sometimes it will say it has added, usually not. When it says it has added it, it doesn't appear in the devices list. shut down and pulled power from hub. got this for several minutes.
I had a similar experience. First went great, second failed. Resetting the second lock, adding it to the Level Lock app, and then to Hubitat did the trick for me. It paired right away.
Reboot the Hubitat hub between Matter device pairings. There is a known issue that the Hubitat team is aware of and are working on a solution. For now, rebooting between pairings is the recommended workaround.
Also want to add to what @ogiewon said, you can pair directly to hubitat and not need a sharing code. (Unless it requires a TBR then you need you need a google, alexa, or home pod or ideally a Hubitat TBR)
Now I'm totally confused. @Bago got his to work without a TBR. My understanding is that is not possible. Trying it that way get's me this error.
I tried a different hub, it got to the point of asking for a name - further than I got before, then Unable to Add Accessory.
Maybe support can pull the logs of your hub and see what’s happening behind the scenes.
@support_team - Interested?
Now I have a Sensereo Matter over Thread Smoke Detector MS-1 that has dropped of Hubitat. Trying to get it back online using code from Home.
Rebooted hub (again) and tried adding it to Hubitat. Got to the naming portion, but behind it was this message.
Then got message it had been added to Hubitat, but that was a lie.
OK - I have 3 Level Bolt locks on Home and now on Hubitat. Actually, I have 4, but the fourth one I had to join to a different hub. I have three hubs due to different buildings. The three that are included to hub 1 are located in that building. I had to add the fourth one in the building that the lock is located. I have Home Pods in the second building. I was under the impression that I should be able to provision the lock on building 1 hub, but that failed, even after the reboot shuffle. I know I can mesh it from hub 2 to hub 1, but hoping to not have to do that. Am I wrong in my assumption?
