I tried to add this sensor to my C8. I configured it on Alexa and then try to add to HE using the matter id,
Pairing failed at Send NOC and with this message
Pairing failed @ FindOperational with code 50 (Timeout)
I also tried with Matter Bridge Advanced and when trying to do _Discover All I got ERROR during the Matter Bridge and Devices discovery (state BRIDGE_GLOBAL_ELEMENTS_WAIT)
For the first time I had one sensor drop of the network. Even the Meross app would not find it anymore, not even after a reboot.
Run the setup again, and was able to join it to the network again.
Out of the five sensors I have, this is the first one that dropt from the network.
I know this is an older thread, but wondering if I can get some help here (or start a new thread). Added the Meross MS600 to HomeKit first as instructed with the Meross start up guide, then subsequently used Matter setup code to add it to Hubitat C8 Pro. I see the device but seem to be registering any activity in Hubitat (does show any events or logs), even though Meross Log clearly shows itās working.
I havenāt added the Matter Bridge or even a Meross App in Hubitat yet. Didnāt know those even existed. Do I need to? Or what else can I do to set this up correctly?
Oh thank you so much. That did it. I had fiddled around with the Device type, but didnāt know which one was best and didnāt know needed to click Configure afterwards.
I also installed your Advanced Matter Bridge before earlier. Is there any advantage of having this installed? Not sure what it does..
Matter Advanced Bridge will include the MS600 illuminance sensor; however, using the Bridge is more of a workaround and adds unnecessary complexity for a simple mmWave sensor.
If you do not need the illuminance sensor, it is better to stick with the built-in HE drivers.
Thanks so much. I am not planning to use Illuminance part of sensor at this time. But is it okay to just keep The Advanced Matter Bridge app installed even if not in use for now?
is this still a good sensor ? I really want to stop getting on a ladder for batteries and if this work like they should rules to keep lights from turning off get easier !
