I have a number of Matter Devices. This morning, unknown to me until 3 hours later, several of the Tapo P125's dropped offline, both in Apple home and HE. None of my other matter devices was affected. Here's the weird part. I have some only paired with Apple, others only paired with HE, and others paired with both. All the ones that dropped off were ones that were paired with both. None of the single paired ones had any problems. I rebooted my Apple hubs, no luck. I rebooted my router, no luck. I gave all of those time to see if it worked. I finally rebooted my HE Hub. Within a few short minutes they all came back up in both Apple and HE.
So it would seem there was something in the HE side that caused the problem???
I might add all of these have been working fine for months.
It might help to flesh out the problem description a bit. You mention P125, so I am assuming at least some of your devices are Matter over wi-fi .. 2.4 only at that. If you have any Thread devices, were they affected?
When you say you have some paired with both, did you pair with one and then share with the other?
They are all matter over WIFI. Anything that I have paired to both HE and Apple would have been joined to Apple first then shared to HE. Not all of those type of plugs were affected only those paired to both. None of any other matter devices was affected including some Tapo switches.. None of my thread devices was affected.
Well the mystery thickens. I just had 5 of the Tapo S505 switches drop off. All of those are paired to both Apple and HE. And they quit on both Apple and HE. Something weird going on.
I'm a thinking I have a WIFI interference issue. We had a new neighbor move in Nextdoor. When I look at WIFI networks I see one I never saw before and it is pretty strong. So I'm assuming it is the new neighbor.
Being I use Apple devices I had to resurrect an old Android phone to run a WIFI analyzer. It showed severe congestion on Channel 1 which is the channel mine was set at. Neighbors on both sides of me were on Channel 1 also. So I set mine to Channel 6. Will see if that helps.
It could help you. Depending on the size of your house you may also want to look at extra AP's and reduce the TX power. If you are on good terms with the neighbors you may also want to ask them to reduce there TX power to help with interference.
The problem with that is everyone needs to nice and reduce there TX power not just one neighbor for everyone to get the best result.
