Matter Devices - Alexa responds with Devices appear to be off-line when they are not off-line
I have been adding more Matter devices lately and occasionally encounter this issue. Since I have Alexa integrated with Hubitat, I use mostly voice commands on most devices. For example, I can say "Alexa turn on the guest lights" and the lights will come on. Then if I say, "Alexa, turn the guest lights purple" it will turn them purple, but then Alexa will respond with "the devices appear off-line, please check...." However, the command to make them purple did indeed make them purple so why is it telling me they appear off-line? It can happen with any command, at any time, usually with multiple commands. But it can happen with initial command with any of the Matter devices. I did enable Command Retry on the Hubitat thinking that may help, but it still happens. Anything anyone is aware of that maybe I did not enabled or a setting that may not be correct? Thanks!
It's moved recently but you can set a do not wait for response for a device within the skills app to get around the notification. Some Matter devices take a fraction of a second too long to respond and Alexa gets impatient and says that the device is offline.
I had several devices, mostly lights, that started doing exactly that a couple months ago. It was driving me nuts ( a very short drive!) trying to figure it out. Not real sure what the actual cause was, but along the line, I disabled the "Alexa" skill in Habitat and then re-enabled it and then everything started working correctly. Not sure if it was coincidence or an actual fix though!!!
I looked and looked all over the Alexa app and could not find any such setting on the Hubitat skill or within the devices on the Alexa app.
Down at the bottom of the screen make sure this is turned on:
then this will show up on each device:
Click the link and the skill/app will assume that the device will respond and notify Alexa that all is good immediately instead of waiting for the device.
OK, thanks the confusion was from the thought that it was in the Alexa app when I should have been looking in the Hubitat app. I did what you outlined and problem solved. Thank You!
