Martin Jerry DImmer Switch
Hi All,
Noob here, new HE owner. Having fun and enjoying all the posts here. I have managed to port over all my devices from Wink hub. They have all been Zigbee and Z-Wave. I also got the drivers from the community for the LIFX Strips I have as under cabinet lighting. Now I'm looking to see if anyone has created drivers for Martin Jerry Dimmer switches. They are wifi (LAN) switches. I bought them from Amazon - https://www.amazon.com/gp/product/B07HJSJ6VG/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Here is a link to the manufacturers website - http://www.martinjerry.com/sd01support
I found some code on github for another hub. esphome_martin-jerry-mj-sd01-dimmer/martin_jerry_mj_sd01_dimmer.yaml at master ยท mjoshd/esphome_martin-jerry-mj-sd01-dimmer ยท GitHub
I haven't found anything here for the HE hub. I'm no coder but just for kicks I took this code and pasted into a new driver page and hit save. Of course I got an error.
I was wondering if anyone here had the skills to port this over.
Looking forward to any responses.
Mike
You could look if there is a device handler for smartthings. The code of smartthings is almost the same as for Hubitat. So it's easier to get it to work.
Thanks for the response @frits but nothing on github or the smartthings community.
I can't find anything on their own website about some sort of local API or anything like that. So the chances are slim.
Could use this too.
If you flash it with Tasmota it works with my Closed Beta driver. There's more info in my driver thread.
