Home automation has made it to Mars!
Communications from Ingenuity to the rover are made through a Zigbee radio link over 900 MHz SiFlex chipsets mounted in the rover and helicopter. The links to Earth are made via the rover and Mars orbiters.
I suppose they couldn’t use Zigbee easily for the downlink as the bridges would move to much
I hope they packed a few extra repeaters.
No regulations on Mars for RF power.. Just because it’s zigbee, doesn’t mean they didn’t pump up the power.
They’re also using 900 MHz and not 2.4 GHz. The lower frequency goes through the construction materials used to make the Mars set at the Disney studios really well.
Believe it or not.. Zigbee actually supports 900Mhz.. Haven’t seen any devices that support that though..
From Wikipedia:
This standard specifies operation in the unlicensed 2.4 to 2.4835 [29]GHz (worldwide), 902 to 928 MHz (Americas and Australia) and 868 to 868.6 MHz (Europe) ISM bands.
Ecobee thermostats have a 915-930 MHz zigbee radio used to communicate with their remote sensors. They use some proprietary encryption, but the transport is zigbee.
You would definitely need a few thermostats on Mars....
I'm wondering how they dealt with the effects of radiation.
oooohhhh the zigbee!!!!
