Manual running rules
greetings,
In my old home control software I could pick any rule and manually run it at any time. I have not figured out how to make that happen in Hubitatā€˜s rule manager. Anyone have any suggestions.
In the latest version you can open the rule and click on the Run Actions button.
For rules I want to run manually without opening the rule I make a virtual switch as the trigger, so I can operate it from a dashboard or by voice
oh good idea - did not consider that..
@thebearmay, I do not see a run actions button…. I am running 2.3.2.132
Only button I see is Pause Action..
Have to open the rule
my rule screen doesn’t look anything like that
Basic Rule is different than the Rule Machine screenshot shown by thebearmay.
You could import the basic rule into Rule Machine if you want that additional button and it would be fairly easy to also add a virtual switch to RM. Or you could rewrite the current Basic Rule to add a virtual switch.
