Not sure how to report bugs so I just write here my finding:
In Maker Api it is possible to set device where to send Post events. If you use http://xxx.xxx.xxx.xxx/apps/api/204/postURL/192.168.100.11:8080?access_token=xxxxx ......
then in the Maker api it will appear as:
URL to POST device events to
192.168.100.11:8080
however this didnt woked for me and at the end I found out I had to use format like this:
http://192.168.100.11:8080
So I assume the http:// should be there also when seting it by Send POST URL
Port 8080 would be necessary if the hub was sending to itself, but if an outside device is doing the sending then leaving off the port (and defaulting to port 80) will work.
aaiyar
March 11, 2023, 3:06pm
3
Yes. This is also required while sending URLs from Rule Machine.
Don't forget to URL-Encode the parameter as necessary for this to work.
I see, this is what I was missing :). So its all fine. Thanks
Thanks everyone for quick answers.
I used the 8080 just because it was in some Python server example and it didnt matter to me. It was only for test. Thanks
system
Closed
March 10, 2024, 4:54pm
8
