- Re: "command":"startLevelChange","type":["ENUM"]},
What are the ENUM options? How can you indicate what direction to level change? Can you indicate speed or other parameters eg a min or max where to stop?
- Re: "command":"setColor","type":["COLOR_MAP"]},
How do you setColor using this command? How does the "COLOR_MAP" variable have to be defined?
- "command":"configure","type":["n/a"]},
What does this command configure? What variables can you use?
