How can I make these bulbs as bright white as possible?
Don’t use color mode if you want the bulb to be as bright as possible.
Set the color temperature to your preferred warm/cool and set the dim level to 100%.
The human eye is most sensitive to light in the green portion of the color spectrum. If you want the brightest "white" light possible, shoot for a color in the 4000-5000K range.
Use the action in rule machine called “set color temperature.”
Then fill in the color temperature in Kelvin, and also the brightness level in %.
Thank you much that worked!
