I have the Pro Hub, both hubitat C7 and that hub are plugged into same switch and UPS.
It intermittenly connects via Telnet. What causes this
dev:672022-04-06 03:23:22.465 pm errorTelnet connect failed, trying again in 60 seconds...
dev:672022-04-06 03:23:22.462 pm infoLutron Telnet is still offline
dev:672022-04-06 03:22:22.028 pm errorTelnet connect failed, trying again in 60 seconds...
dev:672022-04-06 03:22:22.025 pm infoLutron Telnet is still offline
dev:672022-04-06 03:21:22.242 pm errorTelnet connect failed, trying again in 60 seconds...
dev:672022-04-06 03:21:22.238 pm infoLutron Telnet is still offline
dev:672022-04-06 03:20:22.029 pm errorTelnet connect failed, trying again in 60 seconds...
dev:672022-04-06 03:20:22.026 pm infoLutron Telnet is still offline
dev:672022-04-06 03:19:22.147 pm errorTelnet connect failed, trying again in 60 seconds...
dev:672022-04-06 03:19:22.145 pm infoLutron Telnet is still offline
dev:672022-04-06 03:18:22.456 pm errorTelnet connect failed, trying again in 60 seconds...
dev:672022-04-06 03:18:22.452 pm infoLutron Telnet went offline
dev:672022-04-06 02:34:08.172 pm infoTelnet connection to Lutron interface established
dev:672022-04-06 02:34:08.102 pm infoLutron Telnet went online
dev:672022-04-06 02:33:07.721 pm errorTelnet connect failed, trying again in 60 seconds...
dev:672022-04-06 02:33:07.718 pm infoLutron Telnet is still offline
dev:672022-04-06 02:32:07.613 pm errorTelnet connect failed, trying again in 60
Is your switch a managed switch? I had an odd issue with telnet between HE and Envisalink a ways back. I tried all sorts of stuff but finally ended up disabling STP and LLDP-MED. I have no idea WHY that resolved the issue but it did. I think it's much more likely to be something else (like a cable or negotiation etc) and I did not do the same thing for my Lutron hub. But if you try all those and nothing gets better you might want to try those.
I don't think it is bad ethernet on hubitat, otherwise I would have problems connecting to web interface.
I have tried 3 different cables on Lutron Pro.
It is cheap unmanaged TP Link TL-SG116.
from my desktop to the lutron pro:
ING 192.168.1.25 (192.168.1.25) 56(84) bytes of data.
64 bytes from 192.168.1.25: icmp_seq=1 ttl=64 time=0.391 ms
64 bytes from 192.168.1.25: icmp_seq=2 ttl=64 time=0.366 ms
64 bytes from 192.168.1.25: icmp_seq=3 ttl=64 time=0.361 ms
64 bytes from 192.168.1.25: icmp_seq=4 ttl=64 time=0.406 ms
64 bytes from 192.168.1.25: icmp_seq=5 ttl=64 time=0.427 ms
64 bytes from 192.168.1.25: icmp_seq=6 ttl=64 time=0.348 ms
64 bytes from 192.168.1.25: icmp_seq=7 ttl=64 time=0.386 ms
64 bytes from 192.168.1.25: icmp_seq=8 ttl=64 time=0.323 ms
