What type should be used for a RA2 fan RRD-2AF fan switch?
I don't specifically see a "fan switch" available.
Would "Dimmer" (then call 25%, 50%, 75%, 100%) work?
Thanks,
Kris
Thanks,
Kris
Actually, it's not supported in the current release. We will add it for the next release.
I was wrong, this is supported now. Yes, just use a Lutron Dimmer for it, and it will work as you describe. There is an action available in both Rule Machine and Button Controller called Adjust Fan. This action steps through three settings of a dimmer based fan (so it would miss one of the four speeds for the Lutron fan controller -- Low would be skipped). However, you could use Rule Machine or Button Controller in other ways to control it.
