Hi all, I found a previous thread that indicated that driver support was coming soon for RA2 keypad hold/double-tap actions "Lutron Pico Keypads: Held/Double-Tap?"
Does anyone know if this actually occurred? I just tried to create a Rule Manager rule for hold and double-tap and it doesn't seem to work, nor do any hold/double-tap events show up in Hubitat logs.
I'm using Platform Version 2.3.5.152, Hardware Version Rev C-8.
If I open up a keypad device, I see the commands "Led Off, Led On, Lutron Keypad, Parse, Push, Release, Updated". The devices are set as "k" type in the configurator.
You need to update your hub to 2.3.6.146, the latest. Also, confirm that the driver (Type) shown is Lutron See Touch Keypad. If it isn't that, change to that.
Just had a chance to dig in here again. Turns out I'm seeing this across many (all?) keypad devices, even after explicitly hitting Save Device/Preferences.
Here's a screenshot of one particular keypad throwing these errors, anything jump out at you?
I managed to get this working. Just doing Save Device/Preferences wasn't enough, but adding a child button, saving, and then removing it and saving again did the trick.
