I’m trying to source out a POE extender for the Lutron pro hub.
Can some others tell me what they are using ?
Will this work ?
Will this work ?
I think it will work.
Just bought it. The pro hub says 5v 300 mA.
This can handle 2.4 Amps
It will work. Have several of that variety.
Okay good.
Just to confirm. As long as the volts match and the amps are higher then the device you are fine. Is that correct?
You don’t want lower or higher volts and you don’t want to little amps...
Is this correct ?
Yes
Yes
It works fine. Just letting others know.
