Lutron Pico
Hey guys. Brand new user here. I am migrating over from a wink hub during to the week long failure. I have multiple caseta switches and remotes. My question is this. Do I need to use a lutron bridge or can I just add the switches directly as was the case with the wink hub?
Welcome to the HE community, @lghholding!
Yes, you need a Lutron Bridge Pro. The non-Pro will not work.
@lghholding
As @LosinIt indicated, you need the Lutron Caseta Bridge Pro - the part number is L-BDGPRO2-WH. I'm mentioning the part number because there is an outdated model called L-BDGPRO-WH, which will not work.
Hubitat has detailed instructions on how to integrate Lutron devices paired to the Caseta Bridge Pro bridge available here:
https://docs.hubitat.com/index.php?title=Lutron_Integrator
Wink was the last hub to have Lutron built in. So you will need a Lutron Bridge of some type to connect to any hub out there. In our case, we want the Bridge PRO so we can connect to it locally via something called Telnet.
