I have a working lutron integrator app running. I have a list of devices. They all show up in the devices list. Now I have a new device. I added to the integrator’s config list, but it doesn’t show up in the hubitat device list. any trick to this. Should i delete the lutron hub from hubitat and try again?
Did you hit Done when you were finished in the Lutron Integration app? Are you using interactive or "manual"/CSV setup? Any errors in Logs?
I would not delete the Lutron Telnet device -- though it's likely the app would re-create it, and it's just unlikely to help; definitely don't remove the app unless you aren't using the devices in any apps yet, as it will also remove those.
I think I did hit done! Will try again.
