@bobbyD or @bravenel What does this entry mean in the logs listed under Lutron Telnet? At first I thought it might be a misidentified device based on "34" in the error but I also got that same message but with "36" when I updated the Lutron Integration. Thanks
2019-01-24 03:26:21.915 pm inforcvd: ERROR,5 GNET> ~OUTPUT,34,1,0.00
That's an error from Lutron, presumably about the prior message. Not the one with 34. It may not matter, unless you are seeing some bad behavior. Did you by any chance remove a device from the Lutron system?
Thanks. No I have not removed anything from the Lutron hub. And BTW I am so glad I went this route rather than the GE switch route. Of course still have a number of GE zwave and zigbee switches in closets for the most part to build a core mesh. Anyway, I am not noticing a weird behavior on the Lutron side but will keep an eye out.
Found it. Had a the label and ID flip flopped in the integration app. As soon as I changed that and logs were clean.
