Lutron Dimmer Not Appearing in Devices
Hello,
After successfully adding many Lutron devices, I am having trouble adding a new switch. I have added the dimmer in the Lutron integration, and the device ID is correct. However, the dimmer doesn't show up in the devices list.
Any thoughts?
Thanks!
Kevin
Sometimes it takes a few mins. What does the line look like in the integration?
Double-check there are no spaces after the commas in the integration Config List, and that little "d" was used (assuming it's a dimmer not switch), and the integration 1- or 2-digit # is correct?
