Mine seems to be. Like it’s thinking what level to be. Is that normal?
Just be sure I understand the question, you have a Lutron Pico remote directly paired to a Caseta Dimmer, right? Pressing the favorite/middle/round button should result in an instant response from the Caseta Dimmer.
I just ran a test and the result was instantaneous. The dimmer does ramp up from ‘off’ to the dim level of the favorite button, so there is that delay.
Just in case it matters… for any Pico remotes that I use as 3-way switches paired directly to a Caseta dimmer, I do NOT add those Pico remotes to Hubitat.
Thank you
