Trying to move from Eisy to Hubitat. I have installed 2 Hubitat’s. One is in a out building with 3 zwave devices. I am happy so far.
Being able to use the ELK’s zones is a critical part of this migration. I downloaded/installed the ELK app and drivers. When I try to import devices/zones I get this “java.lang.NullPointerException: Cannot invoke method padLeft() on null object on line 417 (method installed)”.
The Eisy works fine. I power it down while working on getting the Hubitat installed. I checked user codes etc. with ELKRP2. I’m lost at where to go from here. Thanks in advance for any help. Jack
Welcome to the community. I am not familiar with Eisy/ELK so I can’t help you. But if you do a search on ELKM1 there is a post for the community app (this is not an official Hubitat app). Looks like it has been closed but maybe there is some information in there that will help. As @oldcomputerwiz stated in your previous post, you can still try to post there as well and maybe someone in that thread will respond. Or possible @captncode can help as he is the author of this version of the app. Good luck and don’t give up. Someone here that knows this app and devices will eventually see your post and try to help.
Edit- Just saw this one as well. Again not sure it will do what you want
If you're starting from scratch with a reasonable idea how the alarm works then if suggest going with the captncode integration as it is more complete than my own. But easy enough to try then both if needed
