I agree, I already moved Button 1 and Button 4 on that piston to the button controller app. Button 1 toggle's the ceiling light on/off. Button 4 toggles a lamp on/off.
Edit: I have also re-uploaded a non-obscured picture of the piston so it makes more sense to everyone.
As said above, start by splitting them into separate flows. You have like 4 or 11 things in one piston there. Each one of those 11 action sets will likely become a separate rule. Looks like a variety of standard rules and triggered rules.
Is the purpose of the Button2 and Button3 variables just to separate the naptime and bedtime actions from each other? In other words...if you split that piston into two, one to handle the naptime actions and another to handle the bedtime actions, could you get rid of the variables? That's what I'm seeing...
Also, what is this device and what is the asleep() command? Thermostat?
Actions when True
-- Turn off Nursery Blind and Nursery Light
-- Run asleep() on the thermostat (not sure what this means but copying the action from the piston)
Actions when False
-- Turn off Nursery Fan and {:f305} device
-- Run resumeProgram() on the thermostat
NapTime Rule 2: Triggered Rule
Trigger
-- NapTime switch turns on
Conditions
-- Thermostat humidity <= 45
Rule
Actions when True
-- Turn on {:f3057} device
BedTime Rule 1: Standard rule
Conditions
-- BedTime switch on
Rule
Actions when True
-- Turn on {:d1ab} device
Actions when False
BedTime Rule 2: Triggered Rule
Trigger
-- BedTime switch turns on
Conditions
-- Thermostat humidity <= 55
Rule
Actions when True
NapTime or BedTime Rule: Triggered Rule
Triggers
Conditions
-- Thermostat temp >= 75
Rule
Actions when True
-- Set Nursery Fan to 20% (you shouldn't need a separate Turn On command like you have in the piston, setting the level also turns the device on)
@destructure00 Thank you for your assistance! I got everything setup except forcing the Ecobee into Sleep mode as apparently the native driver doesn't support this operation yet?
There is a port of Ecobee Suite from ST that supports setting the mode through a custom command from Rule Machine. Just have to make sure that you use the correct parameters. You need to use 2 of them, first the mode, with correct capitalization. So Sleep, Away, Home, etc. And the second is the hold time. It too must be the correct capitalization: indefinite, nextTransition, holdHours. If you use hours, you need a third parameter, the number of hours to hold. Unfortunately, you have to save all the parameters with the command. So, I have 6 custom commands, two each for each mode (I don't use hours).
