Trying to debug why lights keep turning off on my wife. WAF all time low right now.
In any case, how can I trace the cause. Here is the effect:
Something is firing rapid 'OFF' commands to that light. But how do I trace it.
Does the system track the trigger elsewhere?
This light is tied to a group called 'Inside Lights Group' (which is also a virtual switch for tracking purposes [both a rule and a virtual switch of the same name]) which mass turns off the lights if it gets so bright out outside. However, our Kitchen is a little dark and if the wife is home and cooking/cleaning, she likes to light it up even so. Therefore, I have a the rule that turns the lights off for brightness tied to an override switch - simple virtual switch, that if on, makes the brightness condition false and does not fire the off command. It generally seems to work. Logs for the virtual Inside lights group switch make sense with her interacting with the system:
Lights turned off this morning (its a sunny day here today): at 7:13am, she enabled the override and manually turned the lights back on.
General logs then show this:
While the exact seconds do not line up with my first screen shot, those times at 8:04am are all close to the times the K Pendants turned off. But why?
The override switch is on:
And the virtual Inside Lights switch does not have logs of being turned off.
As I review this, I could ask this more simply....
The virtual switch Events page (2 events today):
The virtual switch Log page:
Lots of logs from today. Why?
