Login Security Missing
New user here, setting up hub and the login security is missing from the settings page. I had updated to the latest version prior to trying to do anything. advanced options is enabled.
I found a post related to this in the community but no posted resolution.
Version info
Hubitat Elevation® Platform Version
2.2.8.156
Hardware Version
Rev C-7
Most people leave login security off. It's no big deal as long as you don't port forward from your router. If you feel you must have it on. In your browser, go to yourhubip then click settings, then hub login an security. If you don't see it, click the show advanced options switch
Thats the point of my post - hub login security does not appear in the settings either with or without the advanced options. Same results with all 4 browsers I tried.
Have you tried rebooting the hub?
Yes, rebooting and also power cycling.
Can you post a screen cap?
Apparently not, I get the message "sorry, you cant embed media items in a post", kind of odd given there is an add picture button if you cant use it.
You should be able to cut and paste it into the message
I get exactly the same error message
Need to have been a member longer than a few hours…
lol.. I did wonder about that. Ill try again tomorrow,
Not sure what's going on, but direct link to the page is http://your.hubs.ip.here/hub/userAdmin
