Just got a hubitat... working on getting a triggered event to send
a http get request to my HP mini server ... to test i set up the hub to
send a command once every hour... My HP is receiving the command
and I am tweaking the software on that end to recognize the hub...
Problem l left for a while leaving logging running...
The current date/time on my screenshot for the hub shows 2018-11-23 22:42:38 EST
The last log entry shows 2018-11-24 03:30:00.154 ....
I am using a periodic/trigger once per hour sending
an http get request... I am not seeing extra http requests at my server end
.... Why would an event log with a date and time in the future?!
Attached are the screen shots of my situation...
hub_detail|458x500
Ok... Thought it out....
Log probably using UTC... which would make it 5 hours off...
Answered my own question...
thanks for listening....
Update your location settings, it should pick up your correct time zone.
A little bit more interesting....
I had set up my location using Lat/Log values obtained from
my iPhone and converted from deg/min/sec to a decimal value...
When i noticed the wrong log times, the location tab showed correct
values... The Hub detail tab showed the correct time and timezone....
only the log was wrong...
Because of your response ... which let me know that what I was seeing
was not normal... I did a reboot of the hub... the log is now correctly
reporting date and time....thanks...
I think I may have had to reboot after changing mine too.
I had a strange thing happen this afternoon -- all of a sudden all of my "Last Activity" date and times in Devices suddenly changed to 2014-12-31 with different times ranging from 10:25:32 PM EST to around 10:57 AM -- then I restarted the hub and a bunch of them went back to their last real activity -- but some still remain. What would cause this? Where are the dates and times being pulled from in HB and they seem to be slowly reverting back to 2019 -- as seen in the pic.
