Logging dashboard access
Hello, I have setup a temporary user and assigned them a dashboard
The user will be checking in on pets at my home while I am on vacation
They will be using the dashboard to disable the alarm and open up the house.
I can't seem to find any type of logging for dashboard access that will show when these rights are used.
You can go to the 3 dot menu in a particular device on the dashboard, and there will be a "History" button in the upper right corner of the popup.
But if I was trying to track access to a particular device (like your alarm) I would use the Notifications app, OR make a rule of some type to send you a message whenever this device was used. That would be more proactive instead of looking at a history.
