Logging bug with built-in Google Audio driver?
Not a big deal, but I think its an easy fix and figured I should report it to the Hubitat Staff. If this were a user-defined driver I'm pretty sure I could easily fix this myself. But since a built-in driver we (owners/users) don't have access to the driver code to diagnose and/or fix it.
Not sure if this needs to go to @bravenel or someone else...
I'm using the built-in Google Audio driver to send "speak" commands to a Google Mini speaker. It appears that I always get Info and Debug logs reported even though the device preferences have logging disable.
thanks, we'll get this sorted in the next release.
Could you add the option to send the initialize command before sending any other command (eg speak), this would remove the need for all the Chromecast helper and reduced. Load on the hub.
Could have a optional toggle in the preferences
