Just noticed the Log time is off. Showing an hour greater than it is. ...and no time change yet. Anyone else seeing that?
My Time zone and time is correct under Hub Details.
I was just going to post the same thing.
Had to go to Setting > Hub Details > "Update Time from Browser Time".
The time on "Hub Details" is correct but I still went ahead and updates time from browser anyway. ...but the timestamps on the "Log" is incorrect..
It appears on my C5 hub running firmware v2.1.6.117, the timestamps in Live Logs is correct...however Past Logs are showing timestamps 1 hour into the future.
My C3 and C4 hubs are still running 2.1.5 and timestamps in both Live Logs and Past Logs appear correct.
tagging @bravenel and @chuck.schwer
I did the update from hub, and doing a Z-Wave Repair right now and have the correct time showing now.
Looks like around 10pm my time jumped ahead by an hour. ...but only on the Logs
Yep, around 10pm (EST) was when I noticed it.
I wonder if it is related to the upcoming Daylight Savings Time change?
I thought the same but I'm going to go ahead and update to v2.1.6.118 anyway.
The v2.1.6.118 update didn't help. I'll wait out the time change and check it tomorrow to see if it corrects itself. Hadn't seen others with the same problem.
Here is a screenshot of my Live Logs, which show the correct timestamp just a few minutes ago.
And here is the same data from Past Logs, which is an hour ahead since ~10pm EDT tonight.
I noticed my past logs are an hour ahead but everything else was normal so I searched the forum and see that several people saw this last year the evening before Daylight Savings Ended.
Strange little bug ...
