New user, started adding, have read the multitude of docs, videos, and read from all the great folks here. Thank you very much!
So........ getting an error in the logs, may be nothing, but I don't know. Recently added the Lutron SmartBridge Pro bridge, per Hubitat excellent docs.
Not sure the error is from my Lutron integration.......... but I see "heartbeat", then next line.. error "enum 06", or something. I click on the Lutron telnet" logs. I'll try to paste below.
Again, thank you very, very much to anyone that may try to help me!
Bill dev:142021-02-11 04:45:02.098 pm debugheartbeat- message received...
It's the Lutron Telnet device. If your Lutron devices are working as expected, you can probably disregard that error. Could be simply a transient hiccup with the telnet connection.
@mike.maxwell
Mike - thank you very much. As an (old ) retired network guy, I hate seeing "error" in a log.
Esp, if it's repeated a zillion times!
OK... my 1'st Lutron integrated light, is definitely working!
So....... full steam ahead....... block my eyes to "error" notes.
@mike.maxwell
Mike... again... thanks very much. Good tip.
I did leave it running, as I am trying to learn, and also wanting to see if I make any errors, setting up.
Do realize logs running could impose some CPU penalty, so as u mention, I'll stop that in a bit.
Everyone....... THANK YOU!!!
Bill
Just wanted to let you know that the log entry you pasted above is a "debug" log, and not an "error" log. Error logs would have a red error in them.
Debug logs appear only when debugging is turned on for a particular device (in this case, the Lutron Telnet device). For the built-in drivers, debug logging turns itself off in 30 minutes.
