2.2.5.119 C4
I was learning the details of the attached code. Toward that end I added some additional log entries.
For ease of reading the logs, at the entry of every message to parse I log an underline "_"
I also added the code line numbers to the debug description.
When I started to look at the logs in depth I found some entries that didn't follow the code (as I understand it).
Specifically the area circled on the log screenshot.
The _ is logged indicating a new message has entered the Parse code.
Then a line 28 message.
Then another _ is logged. This would mean the " if (description?.startsWith('read attr -')) was false. But the data shows that not to be the case. And if it was simply the if (description?.startsWith('read attr -')) was false then the else at line 41 would fire but it didn't log.
So are the active debug lines 100% correct, OR I'm missing something.
// Zigbee Basic Parse - good for investigating the parsed map information
// 2021-01-27 - successfully parses additionaAttr
metadata
definition(name: "Zigbee Basic", namespace: "johnrob", author: "johnr")
capability "Actuator"
capability "Sensor"
capability "Configuration"
capability "Temperature Measurement"
capability "PressureMeasurement"
capability "Relative Humidity Measurement"
preferences
section
//input "enableTrace", "bool", title: "Enable trace logging?", description: "Show high-level activities during the operation of the device?", defaultValue: false, required: false, multiple: false
//input "enableDebug", "bool", title: "Enable debug logging?", description: "Show detailed responses to device commands?", defaultValue: false, required: false, multiple: false
} // --- metadata ---
def parse(String description)
log.debug " _"
log.debug " 28 Raw Description#$description"
if (description?.startsWith('read attr -')){
def descMap = zigbee.parseDescriptionAsMap(description)
log.debug " 32 descMap#$descMap"
def otherAttrs =descMap?.additionalAttrs
log.debug " 35 other Attrs#${otherAttrs}"
otherAttrs.each{
log.debug " 37 addAttrs#${it}"
log.debug " 38 addAttrs_Val#${it.value}"
} else {
log.debug " 41 no read attr -"
} // --- parse ---
