How do I setup a rule to lock (check) at 9pm?
If all you want to do is lock the door at 9:00pm this should do it. You may get an error in the logs if the lock is already locked, it won't effect the rule though. You could check it first and only lock it if it isn't already locked.
For your trigger select 'certain time' and for your action select the locks you want to lock.
That worked thanks
