I been using Lock Code Manager for a while with two Schlage locks and 3 users/codes
I had to replace one of the locks recently and was able to configure it and add the users without too many issues
I'm trying to add a fourth user/code to the locks now
I tried to add a user, select a code for him and select both of my locks.
When I press done I get no errors, but the users is not added and in the logs I don't see anything sent to the locks
I also tried just to add the user without selecting the locks and the result was the same
The code I'm using is the same length as my other codes
I partially solved the problem
I was able to add the user by selecting one lock at the time
So if I select both locks when I add the user nothing happens, but if I select just one lick it adds the user
However I still have an issue
I was able to add the user to one of the locks without any error
The second lock just keeps failing and in the log it shows something like this:
2021-11-01 15:40:31.805 debugprocessJobs- try job:[61_4:[code:111111, name:XXXXXX, codeState:pe, retry:0]]
Both lock are Z-Wave Plus and both of them have Z-Wave Plus light switches just next to them , so connectivity should not be an issue
