Lock Code Manager/Schlage Lock Driver/Database broken when using CodeLength 6
@mike.maxwell
"Houston, we have a problem . . . "
Mike, the above is self explanatory. I found a post going back to April, which also reported a similar issue with Set Code Length - see below. I tried that suggestion of manually setting the code length to 6 in the lock, and that resolved my issues. So, as reported in both threads, there seems to be a bug with Set Code Length.
Then, I uncovered another issue in LCM. Here is the simplified use case:
  1. Add new users A & B in LCM
  2. Change B to disabled
  3. Add another new user C
  4. It will not show up under the user list in LCM, but will appear as a "child" under B if you open that up to change the Disable option . . . .
LCM seems that it requires a lot of cleanup work. There is some funky behavior between it and the Status section in the Driver page. In addition, adding/deleting/changing users in LCM now results in numerous warnings/errors being thrown in Logs.
