Just decided to mess with lock code manager for the first time. I was able to figure out how to set codes and what not. Tho for some reason I have like 250 user codes, seems the garage lock populated every user code idky. Anyway I’m Curious about the report tab as I figured it would give details on the locks last user code entered and what not. Tho there’s nothing there. I even changed the options for the reports within the options tab. Am I right or am I wrong here?
It does not do that. But you can go to the particular lock device page, and under Current States in the upper right corner, you can see this info. In addition, the lock device page Events button shows the last user code used.
What the Lock Manager does show is how many times each code was used.
This would be a good enhancement though, maybe the team would consider it?
