Lock Code Manager oddness
I have two Lockwood (Yale) locks. The older one the same as an Assured Deadbolt Keypad with Zigbee and the newer the same as an Assure 2 something on Z-Wave.
I never user Lock Code Manager when I had the first lock, I just used to use the device page and set/delete/get codes.
Long story but I had to get the new lock - fire rated - to replace the first which I am repurposing, but when I tried to manually add codes it never accepted the names which I then realised was because Lock Code Manager was installed and watching.
I am now trying to maintain codes on both but the older lock fails and in the device log I get "setCode X" over and over again. Removing Lock Code Manager, manually adding codes mostly works - sometimes I have to wake the lock up by locking/unlocking it, but it never repeats the setCode command and eventually works. Re-adding LCM and the problem returns.
I ahev worked around it for now by manually adding the code with the same names on both locks and re-adding LCM, but I am not sure what LCM gets me if I need to manage the old lock in the future.
The newer lock works fine with LCM.
What do I start debugging to help?
