Found a bug trying to ADD A NEW USER if any of the Existing users are set to Disabled. Logs show the following: "java.lang.NullPointerException: Cannot get property 'lockCodes' on null object (codeManagement)".
Once all Existing users like Guest#2 are set to Enabled then Lock Code Manager works correctly to ADD a New User.
You are supposed to start with a wiped keypad with no users defined. That's the only way that LCM works because it can be used to sync users across multiple keypads.
Does lock code manager work with the Enable lockCode encryption enabled on the lock devices?
I do not have any experience with encrypted locks, you may want to flag Hubitat support staff.
It does on my Schlage FE599 Z-Wave.
Yes
Great, also where would I go to see who unlocked a door, I would imaging that is what the Name field is for? I'm not familiar with the logging yet.
Thanks.
