Like many users of Hubitat, I have been experiencing events that turn the zigbee radio offline since the new C8 code is out (even though I am still on the C7). To work around this annoying issue, I configured a rule such as this one
but it never triggered:
One again, my home went for hours without zigbee working and without the hub fixing itself.
Didn't work for me either. I'm only experiencing 8 second zigbee outages though; not as serious as you. I also tried to simulate by turning off zigbee radio. That didn't work either.
Does "zigbeeOff" show up as a location event? From the logs you posted, "zigbeeStatus" appears to be the location event.
The options are as follow:
Thanks for your feedback. We are looking into it.
It just seems to have worked for me.
I'm using hub version 2.3.5.140.
Nice. They did say they would fix the Zigbee off event in a new release, although the release notes for 140 don’t mention this
I know. That's why I'm going to let the rule ride for a while. The 8 second outages don't bother me that much, but I'm curious if it indeed works.
I wonder if you could use it in a rule with a timed delay, so the little outages won't reboot the hub. I'll have to see.
And here it is in Location Events log:
