Location blank after soft reset, and mode stuck
Hi, so my hub finally got the slowdown bug yesterday, so I performed a soft reset and restore. This morning the hub is stuck in night mode. Due, I found, to the location being blank, so it had no sunrise time.
Is it normal for location settings to be wiped after a soft reset and restore?
I went in and set the location and performed a reboot for good measure, but after it restarted, the hub was still in Night mode. The system time is correct.
Can I propose that the hub runs Mode Manager once at boot time so the mode gets correctly set based on the time of day? (this assumes of course that time of day has been set correctly by NTP, perhaps Mode Manager could wait a bit, or check that NTP has succeeded before running).
A way to run Mode Manager manually or from RM would be useful also.
I whipped this up to set the mode on system startup.
