Local variable question
I have two rules, call them primary and secondary. The secondary rule does a bunch of stuff but has no triggers - it can only be called from another rule, in this case the primary.I have local variables in the primary rule. When I call the secondary rule are those local variables defined in the primary rule visible to the secondary rule?
Yeah that's how I assumed it would work. Just was seeing some odd results and wondered if that was the cause. Will look further.
