Local variable after 2.2.5.130 update are not working all
Hello, after 2.2.5.130 update I have a list of local variable connectors which are not working from dashboard. I download now 2.2.5.131 hope it will be fixed
Not working after update :frowning:
not exactly sure what you mean.. see the 67 on the dashboard that is a local variable.. are you describing something different
In my case this noted "temporizator ON" - boolean is not set the value to the variable...
I can't change any more to false or true, the variable from the connected dashboard
and global variable :frowning: connector dammaged
mine are fine.. i assume maybe some db corruption before update.. do you have an old backup or can you delete and recreated variable or connector.
I will load backup ... I rolled back the version to 128, but no change
