I have been getting an alert that local database backup failed on all 4 of my production hubs. If it was just one I would assume it’s a corrupted database and a soft reset would solve it, however it happens on all 4 of my hubs.
Currently running 2.3.4.134 but this was also happening on prior 2.3.4.132 release too. I upgraded to 134 hoping it would fix it but this just happened again last night.
I have been seeing this error the last couple update versions. Currently on 2.3.4.148. Not sure if it is related, but I have not been able to manually create a backup file downloaded to my PC. Not sure if I'm mostly alone here or others have been seeing this issue too, just wanted to bring it up incase I am alone here, thanks!
Edit: This error I am seeing in chrome, when the backup fails to download
My issue ended up being caused by my NodeRed automation that downloads a hub backup around the same time of the hub’s maintenance. I moved out the timing of this flow and things are good.
@gopher.ny can look at your engineering logs to see if something else is causing it.
I just started getting this error on one of my hubs. I was running 2.3.6 when I saw the message. I have since upgraded to 2.3.7 thinking it would help, but nope. What is the best way to resolve it? Currently running 2.3.7.144. Saw the message on .139 and .140 as well.
EDIT: Looking at the local backups on my hub, none of them are at the scheduled 2:30 AM time.
