I get the following error in the live log having just switched the lamp in question on via the dashboard. Lamp is a Hue bulb connected via Hue Bridge.
Looks like it was caused by an app or instant called "don't turn off if already on". Do you have automation called that?
As the title says, its a Motion Lighting app. This is a built in app. The "don't turn off if already on" is an option within it.
My fault for not paying more attention to the title.
I would remove that motion light instant and create another one to see if the error cleared or go in the motion lighting app and hit done.
That's ok. I'm just going to leave it for support to have a look at, before I change anything. I've seen similar issues posted but am not sure if this was meant to have been fixed by the last hotfix.
@bravenel is this a known bug that you're working on, or a new one?
I believe this bug was fixed in a recent release. What platform version are you on?
As per title, 2.0.4.116.
Sorry. Yes, this bug has been identified and fixed, but will be in the next release.
Bruce, Is this fixed in 2.0.4.117?
No. Fix will be in 2.0.5.
